Creating a break line
Mode
Tool
Tool set
Modes for Creating single lines
Break Line
Dims/Notes
The Break Line tool creates one of three types of break lines: straight, curved, or arc.
On site models, pads with open edges, sometimes called break lines, can be created using the Site Modifier tool (Vectorworks Architect or Landmark required). See Creating a planar pad from grade limits.
To draw a break line:
Click the tool and mode.
Click to place the object in the drawing, and click again to set the rotation. The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited from the Object Info palette.
Parameter
Description
Break Style
Selects the style of the break line (Straight, Curved, or Arc)
Break Width
Indicates the width of the break only
Break Height
Indicates the height of the break only
Break Radius
Sets the radius of the break only
Number of Breaks
Indicates whether a single or multiple break should be drawn
Creating double lines
